I didn't say dangerous nor did I imply it. I said defensive and mean-spirited. Perhaps reading and comprehension aren't your strongest suits.
Haha .. Look at your post above and the whining about AMD hardliners .... Get a grip man
This is some way to treat someone just asking for help.
I've found AMD hardliners to be quite defensive and rather mean-spirited. I'd hate to ask for help if I ever bought an AMD product.
Was the UEFI only theory tested?
I doubt the card killed the mobo - there's no reason why it would be drawing >75W through the PCI-Express slot just to boot.
Wrong. Half the vcore power phases (the VRM is 6 phases) are fed from from the PCIe connector, the other half from the 6-pin.According the BuildZoid who live streamed himself OCing/Watercooling and adding more caps (and attempting hardware volt mods), the GPU takes its power solely from the 6-ping connector, and the PCIe connector feeds the VRAM and possibly other stuff on the PCB.
if you want to watch his vids form last night (long)
Watch his 'Overclocking Livestream 13: RX 480 first session part 2' at 58min.
Dear Mr. Greg,
Thank you for contacting Asus, my name is Allen and I will try my best to assist you with your situation.
Please feel free to rate our service according to the solution provided in the questionnaire that will be sent to you shortly after our reply to your inquiry.
I inform you that usualy the motherboard will not allow the graphics card to draw more than 75W even if the graphics card doesn't have a set limit to this wattage.
Unfortunately we are not able to test if a graphics card that doesn't use the correct limits for the PCIe port can or will damage the motherboard.
We understand that AMD will release a patch for RX 480 in a few days and we advise that you contact the vendor of your graphics card to make sure you have the latest revision installed.
Should you have any further questions, please do not hesitate to get back in touch with us.
Best Regards,
Allen
ASUS Technical Support
Oh, you mean 960 Strix? http://www.pcper.com/reviews/Graphi...s-Radeon-RX-480/Evaluating-ASUS-GTX-960-StrixWho cares? Nvidia cards draw more than 75w. Non story, Non news. blah blah blah
One interesting note on our data compared to what Tom’s Hardware presents – we are using a second order low pass filter to smooth out the data to make it more readable and more indicative of how power draw is handled by the components on the PCB. Tom’s story reported “maximum” power draw at 300 watts for the RX 480 and while that is technically accurate, those figures represent instantaneous power draw. That is interesting data in some circumstances, and may actually indicate other potential issues with excessively noisy power circuitry, but to us, it makes more sense to sample data at a high rate (10 kHz) but to filter it and present it more readable way that better meshes with the continuous power delivery capabilities of the system.
Some gamers have expressed concern over that “maximum” power draw of 300 watts on the RX 480 that Tom’s Hardware reported. While that power measurement is technically accurate, it doesn’t represent the continuous power draw of the hardware. Instead, that measure is a result of a high frequency data acquisition system that may take a reading at the exact moment that a power phase on the card switches. Any DC switching power supply that is riding close to a certain power level is going to exceed that on the leading edges of phase switches for some minute amount of time. This is another reason why our low pass filter on power data can help represent real-world power consumption accurately. That doesn’t mean the spikes they measure are not a potential cause for concern, that’s just not what we are focused on with our testing.
