- 6 Sep 2016
The Shield TV is the best android box you can get but not good value if you don't play games on it.
If it's just movie/tv watching etc you would be better with a Fire TV.
Android TV is designed for TVs so you can use a remote and the apps will work with remote.
The generic android boxes come with poor remotes and an OS designed for touchscreens like mobile or tablet.
Not bothered about that, as I have a powerful learning remote. Hopefully I can get discrete IR codes.
Also with the box I can install the stock android, or android TV version. As long as I can navigate to directory/folder with the stock remote controls IR commands, and play files, that'll be enough. If I want to use it for other Android features, a blutooth micro keyboard/trackpad is about a tenner, so will convert it to a full on powerful smart TV. The unit I have is a audio/video streamer, it's ok but won't play H265 or HVC, or 4K (my TV is 1080p however I guess it could downscale 4K to 1080p)
