Hi guys, right, I'm in a bit of a kerfuffle. Here's my little backstory....
I bought myself a new case for Christmas (Corsair 240) from MM (thanks djay) which then gave me the bug to upgrade my aging, non overclocked system (i5 2400S/P8B75 mobo/R7 260X/8gb ram/Hydro H50). Since then I've bought a Vapor-X 7950 (£70), 16gb Corsair Vengeance Pro ram (£75), 2700K (basically free as bought as part of a bundle then sold spare bits + my 2400S on), an Asus Maximus V Gene (again, bough as part of a bundle but kept cpu (2550K) and case (240 Air) for the stepdaughter), a Hydro H105 cooler (£50) and a few SP120 LED fans (new).
Right, now I've got a decent system for once, which is already oc'd to 4.6, i feel my recently purchased GPU is now a weak link. With a budget of £180ish I'm torn between a GTX 1060 6gb "Reference Design" (seen on OcUK clearance for £188) or an RX 480 8gb RS from auction for £180. Is the RS as bad as the reviews say (Bad cooling/under-volted and cruddy overclocking)? I've only ever owned one nVidia card which was a 8800 GTS 320 but definitely don't consider myself an AMD fanboy and really don't mind switching sides if the RS isn't worth buying.......
I'm open to suggestions
