Another Red And Black Build ^_^
19 Feb 2007
Area 18, ArcCorp
Always wanted to do my own ROG type build and now I finally can :)
The rig is almost done, Just need to neaten up the cables a bit more, 1 or 2 details here and there, A few cable combs and I'm done.
I took the SSD apart, Sanded down the metal shell, Painted it black, Baked it in the oven for just over an hour *This is a real thing :p* and once it cooled I put some Carbon Fiber Di-Noc on to it as well as the HDD.
**Sorry about the picture quality my camera isn't the best
Night Shot -
Top view -
Front view -
Changed the white rings on the SP fans from white to a nice matt black, I did try red but they looked very out of place with the whole build -
Cable combs came in yesterday, Decided to go with transparent -
24 Pin cable comb -
Installed an LED strip along the bottom under the mobo and under the right side of the mobo, No point installing at the top as it wouldn't be very visible and would clash with the white from the fans at the top and rear -
The carbon fiber covered SSD and HDD *Breather hole on the HDD is on the underside* -
Backplate for the Phoebus arrived and installed -
Little video showing the memory lights in action -
And another video showing the reboot process i.e the speed and theme -
Rig Specs
Corsair H100i + 2 x SP 120mm Performance Editions In Push + 2 x AF 120mm White LED Quiet Editions In Pull
Core i7 4770K @ 4.80GHZ 1.34v *managed to get a nicely binned CPU
Asus Maximus VI Formula
Asus R9 290X Matrix Platinum
Avexir Blitz 1.1 Original 16GB 2500MHZ *Only a 100MHZ Overclock*
Asus Xonar Phoebus
Corsair Neutron GTX 240GB *Taken apart, Painted black and carbon fiber put over the top*
2TB Western Digital Caviar Black *Carbon fiber put over the top* + 4TB Western Digital Caviar Black *In the Rear*
Corsair 540 + 1 x 140mm AF White LED Quiet Edition *Rear* + 3 x AF 120mm White LED Quiet Edition *Front*
All braided cables are from Bitfenix.
Very nice, going to start on my own red and black 540 soon, can I ask where you got you the braided cables from? I know they are bitfenix but what website.
Have you tried the red rings on the sp fans? This and an af 140 at the rear would look good. Got a similar theme going except my cables are red white and black, more of a shinier braid though.
Yeah and the red rings on the SP's just looked completely out of place with the rest of the build and I already have an AF at the rear as you can see in the pics as well as 2 on top and 3 in the front ;)
The white from the AF fans contrasts the red and black nicely, If you start having all red it bleaches everything out and starts to look very cheap.
Ahh, forgot they done led versions of the af series. I use a mix of sp's and af's, mostly 120mm ones though as the sp's aren't available in 140mm which my case is fitted with as standard.
The only place I use SP's is on the push part of the H100i as I use AF's on the pull part, Linustechtips did an in depth test with quite a few variations and this one is the best fan configuration on the H100i.
At least mate with the h100 more of your board is visible. Such a nice looking bit of kit the formula. Mine is covered up quite a bit by my k2 air cooler. Fan wise i use the sp PWM models on the cooler and as front intakes, great for moving air through restrictive areas such as hdd cages.
Thanks I will have the same setup but I have red as I got the free red 120mm fans with my msi z97 cant wait lol looks mint
Will look forward to seeing pics mate :D
I did try red fans but then I replaced them all with the white AF's *apart from the 2 x SP's underneath the H100i * as for me anyway, White seems to do a nice job of highlighting the rig rather than washing it out with colour :)
