Another xbox question......
28 Dec 2002
Northern Ireland
hi guys, i have my xbox and hd drive hooked up to my lcd screen via the vga connection and the picture quality is great, however i have it connected to my av amp via an optical cable. The sound is not that good i need to turn my amp right up to get any decent sound and even then its still not that good.
I can tell the difference because i have tried superman returns (HD) in the hd drive and then superman returns in my dvd player and the sound is considerably different, in that it is a lot louder.
Has anyone encountered any similar problems???
Turn the volume up on the Xbox... if you press the guide button, there is a volume button in there... Failing that, if you go to the Media pane, and open up the media player, there is a volume slide/button in there.
Scarylion said:
There is a bug with the HD-DVD Drive where everything is a bit quieter than it should be!
Is this the case with them all, or is it specific drives???
Anyway of fixing it??
ace
Ah, having only received my drive a couple of days ago, and only having one HD-DVD at the moment, I did wonder!
Yep same here.
I'm also running the 360 HD-DVD player through an optical cable to my DVD/amp. I was watching Troy on it the other night and I had to set the volume to 48! Usually if I'm watching an SD-DVD on my DVD player the volume is set at 35, and that's loud enough!
