any ideas?
30 Aug 2011
My fans keeps turning on and off and i have to press the power switch a few more times or wait a for t to turn on and off on its own also i get a plain background screen after bios
so erm press the del key and get into bios?
or whatever the bios key is on ur mobo
u just need to setup ur boot drive n stuff? duno if im missing something here
Not pressing anything at the bios screen gives me a black screen with a blinking cursor. Whenever I press any of the options on my keyboard I get the same so I'm not able to access any of the bios options. I've tried a stick of ram at a time and it hasn't helped.
srsly martrimo no one can give useful help if you dont tell us more info
its like we have to sit here and guess every possible thing^^
tell us what you have done so far and when the problem started, i didnt even know you had installed windows until your last post :)
Sorry, I'll try to sum up everything.
I just built this pc and I've yet to install windows on it. I've made all the connections and then on booting I've received this problem. I've tried disconnecting and reconnecting individual parts but none of it seems to affect the boot.
On boot the pc runs and the fans run but then stop. The computer then reattempts to boot 3 or so more times before it actually succeeds. This is when I can see the bios screen and that's where I'm stuck.
Right, you built your PC, installed OS, all your drivers,everything was fine and now you are having problems.
When did the problem first start?
Did you make any adjustments in the bios or add any hardware, prior to the problem first occurring.
Check that all connecters are firmly connected
