commited said:I think when he said upshift, he meant downshift..
Now it makes sense
Yep, I blip the throttle on downshift. Sounds great, feels great...
It has? I thought people were just assuming.Phal said:Is anyone actually reading this thread?Im pretty sure its already been established that he mean shifting down in gears rather than shifting up.
jonnyc747 said:"4th at around 28 mph."
You must be driving one of these!
...and YOU came to this conclusion how exactly?Phal said:*sigh*
Simon said:It's nothing to do with learning to drive, using the throttle slightly makes for a very smooth gearchange, and as mentioned is part of advanced driver training.
This pretty much sums up everyone's feelings so I've quoted it and I'll say...commited said:if you want to build speed, keep accelerating in 2nd or 3rd up to peak power and then change.
Ken said:This pretty much sums up everyone's feelings so I've quoted it and I'll say...
2nd up to peak power?!
Peak power is at 4000 rpm. Another 500 rpm and it's the redline.
It would take forever to reach 4000 rpm in 2nd. Most of the acceleration would have taken place early in the rev range and if you didn't shift, you would blow the engine I'm sure as it'd be impossible to reach such a high rpm in such a low gear. You'd also look a complete arse as the engine would be making such a racket urging you to change gear. Same is true with 3rd but not as "bad" as 2nd.
My point being contrary to dirtydog's post about changing gear at peak power, it's better, in my case anyway, to change gear soon after peak torque when you feel the acceleration lacking. That way when you shift the revs would have dropped back to peak torque when the next gear is engaged.
I don't really care about the original point of this thread...I'm more concerned about your posts that reflect what I quoted above and dirtydog's point.
This is a 6 gear diesel.
LOL! What are you on about?Ken said:Peak power is at 4000 rpm. Another 500 rpm and it's the redline.
Ken said:You can laugh and I am exaggerating with the blowing up thing but I know for sure it would take you forever to reach 4000 rpm in 2nd. You would have travelled a significant amount of distance if you shift rather then wait till 4000 rpm.
