Gavin said:As header really, the guys over at XDA developers get a bit snotty if u havnt read 40 pages of imformation and dont understand....
Just wondered if anyone wanted to talk me through it and if its worth it?
GuruJockStrap said:I've just flashed the Vario II again to ROM version 2.05 (WM5, AKU 3.3) and the very latest radio version.
Feels much quicker than the previous 1.35 I had on there.
I really feel sorry for those still using the default T-Mobile branded firmware!![]()
err hello then.GuruJockStrap said:I really feel sorry for those still using the default T-Mobile branded firmware!![]()
If your Hermes still has bootloader version 1.04, you should CID-Unlock it first, then you can safely flash any ROM with bootloader >= 1.06. Otherwise it is not recommended to flash ROMs with bootloader >= 1.06.
Flashing instructions if you are in bootloader 1.04 and get a INVALID VENDOR ID error:
Try the following steps:
1. Extract the rom contents by right click (use Winrar)
2. Make sure you are connected through ActiveSync (green icon in system tray).
3. Open ROMUpgradeUT.exe
4. Go through all steps. Eventually you will see your device reset and go into a ROM Flash screen at 0%. You should get an error from the Flash software stating wrong Vendor ID code.
5. Don't disconnect the device or reset it. Close the Flash software.
6. Click on ROMUpgradeUT.exe again and go through all steps. This time it should start flashing the ROM.
7. That's it.
CID?GuruJockStrap said:You don't have to CID unlock anymore.
All the ROM update exe's contain a file that is sent to the phone first which put your handset into a temporary CID unlock mode before flashing. Quite handy for warranty purposes![]()
