This would be my guess, pretty sure your card itself is fine if it's now working normally.Just a driver issue?
Good Evening all,
Thought id post an update.
Problem solved.. I think
Installed Windows 11 after formatting. Installed all latest up to date drivers. Turned machine off, then back on again. Still same issue. Screen still glitches on start up after bios.
But I ran DDU, installed an older version of Amd Adrenaline. 22.12.2. Has worked perfect ever since..
Also did a bios update too
Why would this be the case?
Could it still be a faulty Card. Just a driver issue?
Thanks
If its working fine now
I would just leave it alone
You're not going to take a massive performance hit
By using the slightly older driver
Note the driver/amd software version down
And wait for the next release
Usually they're updated pretty regularly
Rolling back and waiting for the next release fixed
My issues with the nvidia ones
Fair enoughThe driver version T5Turbo has rolled back to is 22.12.2, those were released back in December 2022. They were pretty much public release #2 at launch of GPU.
Putting aside performance issues for games/OS, there will be lot's of bug fixes which have occurred between December 2022 and current drivers.
AMD were making tweaks to GPU clock/voltage behaviour via SMU firmware updates to these GPUs after release for several of the drivers.
I had been logging them for my own purposes and shares on another forum.
surely if it was a psu issue which im assuming you mean transient spikes the entire system would shut down wouldnt it? not justthe gpu ******** the bed
Good Evening all,
Thanks
