On the slightly nervous theme I've no idea what is the best RAM I can get for this (probably 5900x but maybe 5950x)
Should be looking at a nice upgrade I think Tony.I'll be going from a 8700k @ 5ghz and a Pascal Titan to a 5900X 6800XT combo so yeah I'm a little nervous of the amount of improvement I'm going to see with that CPU over the 5ghz 8700k I got.
Fair enough. I'm assuming some earlier reviews will cover this?Literally wait 3 days.
If gaming is your main pass time then I doubt you will see much of an improvement from the CPU for the money spent especially at 1440PI'll be going from a 8700k @ 5ghz and a Pascal Titan to a 5900X 6800XT combo so yeah I'm a little nervous of the amount of improvement I'm going to see with that CPU over the 5ghz 8700k I got.
Have a look at the reviews not long to wait now.theres no questioning the 6800XT being a big jump up from this Titan, the CPU is the upgrade I'm not sure of as I'll be buying a x570 motherboard also. Wondering if maybe I just get the 6800XT and an EK block for now, drop it in the current system and wait for the next gen motherboards and chips.
Good thanks mate.Indeed. How you been anyway? not seen you around for a while, I guess you'll be doing a big upgrade also?
Good thanks mate.
Yeah I think I’ll be upgrading, tented by the 5950x and a 6900xt, but may end up with a 5800x and a 6800xt. It will depend on availability I suspect which I end up going for.
it’s been too quiet with you out of the AMD threads.![]()
On the slightly nervous theme I've no idea what is the best RAM I can get for this (probably 5900x but maybe 5950x).
Would I be better off buying CL16 3600mhz or CL18 4000mhz?
AMD seem to think 4000mhz is the way to go?
I've gone for 3600mhz 8pack rams.... I'm hoping that 3600mhz is enough if not with a bit of luck they might overclock, but not sure if they would reach 4000mhz????
I didn't go 8 pack but I went for crucial ballistix 32gb 3600mhz cl16 - hoping the same if this is the case but I suspect it won't be 4000mhz, more 3800mhz.
