Anyone smarter than me help with this maths question?
Surely brackets make no difference as all subtractions. Would be different if multiply or divide operations?
Me neither. Been going through every possible permutation in an equation solver and can't get it.
6-(5-4)-(4-3) would also work without changing the subtractions, but you need to add another number.
It's either impossible or we are all idiots. 50/50 really.
I remember once upon a time when doing Matrix algebra they used to throw in impossible questions (like asking to add or subtract matrices of different dimensions).
In those cases the correct answer was "No, it can't be done", is this one of those ones?
It's just question d. He's already got all the rest.
I've been using Wolfram Alpha to try a load of combinations quickly.
Even considering negative multiplication, I'm not finding the answer, thinking the teacher made a mistake.
Considering the others are very easy, I don't think this level would be that tricky.
Here's the link if you want to try it, maybe someone else will luck out, or maybe you'll all just waste time doing the same thing I already did.
I'll also point out that all the equations are valid with no brackets because they all resolve to either true or false :cool:
My maths is rusty. Very rusty. I can't see that being possible. Not with just using brackets. And possibly not even proveable without some serious mathematical jiggery pokery.
Must be a typo, surely?
At least putting the following in Wolfram Alpha gives 4
6(-)5-(4-3)=4
Yes, that's cheating, but I suspect the question is broken.. surely you should get merit marks for bucking the system ;)
6(-)5-(4-3)=4
I don't even follow what (-) does to make that 'work'.
It just breaks the WA interpreter..
6(-)5-(4-3) is interpreted as 5-(4-3)
The only way I get 4 from 6, 5, 4, 3 is :
6+5 = 11
-4-3 = -7
11-7 = 4
But the 5 is -5 not +5
NB 6-5-4-3 = -6
6-(5-4-3) is 6-5+4+3 = 8
(i think)
