anyone using ps3 on a monitor via hdmi>dvi cable?
Caporegime
18 Oct 2002
Ireland
Got mine today and updated the firmware, everythings fine, problem im having though is ive a hmdi cable with a dvi connector on the other end, currently trying to hook this to my dell 2005 fpw monitor, anytime i connnect it and switch to hdmi i get the message on the monitor "cannot display this mode".
I kinda assumed that it would work fine and dandy on my monitor like my 360, so far though no luck. :(
Kreeeee said:
Is it outputting at 1080p rather than 720p?
I think so, though saying that ive seen people saying the monitor has to be hdcp compatible as well. At the mo its 480i via composite =/
wouldnt supprise me, from what ive read it has trouble syncing with some HDTV's when using HDMI
in america....not a uk problem.
Try checking your display setting and tell us what you have it as... :)
It does say in the PS3 online manual
If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
Sony make the most stupid mistakes ever. They constantly shoot themselves in the foot for no apparant reason. I don't think having hdcp is going to matter when blu-ray dvds can be ripped straight to a hard drive already.
You do realise sony dont own the hdcp iirc.
sunlitsix said:
is HDCP a default feature with all HDMI connections or just associated with the content stored on the blu-ray discs used?
Part of the HDMI standard is HDCP. I believe that the PS3 uses HDMI 1.3 though?
maybe, i cant find much good info on HDMI and connecting with pc monitors though im guessing its down to the content on the disc.
from my own investigations the problem the poster is encountering is the dvi-d input must be hdcp enabled, it won't work otherwise thats why I have my sights on the e228 from dell which is hdcp enabled.
But it's not necessarily just the games is it?
If you select HDMI as the video output and the display device doesn't have HDCP, you've had it. It's the console full stop.
