** AOC JOIN THE FIGHT WITH A SUB £500 4K VERY NICE MONITOR!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Maybe not quite as stylish as the Samsung model, but for the same money you get a full adjustable stand, vesa 100x100, speakers, more connectivity and a USB hub.
Check this bad boy out and again OcUK is launch partner as we are the most focused 4k store in the UK, as always leading. :)
Stock is expected in June!
AOC U2868PQU 28" 4K 60Hz 1MS Gaming Widescreen Monitor - Black @ £499.99 inc VAT
The U2868PQU from AOC is designed for gamers as it features a rapid 1ms response TN panel with a staggering resolution of 3840x2160. Your games will never have looked so good, but bear in mind to play the latest games at 4k resolutions you will need a minimum of 780Ti or 290X and ideally a pair running crossfire/SLI to play at 4k with maximum details with 60fps or more. This monitor is also 60Hz at 3840x2160 when connected via DisplayPort.
Featuring great connectivity with VGA, DVI, HDMI and DisplayPorts along with a full height adjust, pivot and swivel stand with VESA 100x100 support. Making the AOC U2868PQU ideal for eye-finity/surround setups. The monitors also includes stereo speakers as well
Specification:-
- Size with stand (W x H x D ) : 658.9x560.6x245 (mm)
- Without stand (W x H x D ): 658.9x395.8x50 (mm)
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 80,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x HDMI, 1x DisplayPort, 1x DVI, 1x VGA, 1x USB Hub
- USB Hub: Yes
- Speakers: Yes
- Warranty: 3yr
Only £499.99 inc VAT.
ORDER NOW
Same panel as the samsung? Displayport 1.2 needed?
Yes, Samsung make all TN panels. ;)
Yes DisplayPort 1.2!
This for the same money is great, more connectivity, adjustable stand, VESA so you could mount three onto a monitor stand and an extra years warranty (3yr). :)
What's with all these killer waiting times :p
There's only one actually affordable 4K monitor in stock, and that's the 24" 900 quid Dell :p
800 quid at OcUK! :)
That is the leadtime, we have secured ourselves as launch partner, so were making noise as 4k will be one of the biggest events later this year and I intend of having the best range and deals in the UK. :)
For 4K, OCUK's definitely leading the way, your prior employers have practically nil.
It's just a killer with the leadtimes, the Samsung is frustrating (With the korean sellers etc on the bay, but I wouldn't chance it, same as I didn't do one of those 1440P monitors)
Buy a Korean one, you have no warranty with Samsung, not a leg to stand on and your reliant on dealing with the Ebay seller if it goes wrong, good look if that happens especially after a year of ownership. Plus you have to pay import duties/taxes on top of the Ebay price, unless you get lucky and customs don't spot it, which will make it nearly £100 more expensive after admin charges.
That's entirely my point.
It's not worth the risk at all.
Good to see another sub £500 4K monitor.
Although after playing around in Bf4 last night I think I will have to give them a miss until I can get a new GPU.
Brilliant stuff. Definitely wasn't expecting 4K monitors to be coming in at the £500 mark. Very impressed. The GPU horsepower needed though would probably put me off upgrading from 1440p. G-Sync Vs 4K could be an interesting battle in the summer!
So these are technically available now on the bay at less than £500 or more than £500? True about the warranty..............I bet 4k is prone to fault this early on so good to have a warranty. Having said that I went to a strangers house and paid cash for an out of warranty dell 2008 30 incher and it's still working perfectly.
very nice but you need to add another £500 on for the cost of the second 290x /780ti to run it with all the eye candy on at 60fps.
when will these start to come in stock or have i missed that bit.Plus how would the gtx780ti 6gb cope with this monitor would i still need to sli it.
£464 + VAT and any other import duties/admin charges.
We are £499 including VAT, Ebay will be £550-£600 landed with no warranty.
Gpu grunt is the killer, to game at a decent frame rate you really need 2X290 or 780, that's £650 of graphics card plus £500 for the monitor. Only for the well off sadly which is your market here ocuk. :eek:
