You should then get this screen:-
Tick "Add a shortcut to this connection to my desktop" and then click "Finish".
Upon clicking the desktop shortcut, you should get this screen:-
Click connect and thats you online.
Make sure your username and password are exactly as they are as if you were entering them into the AOL screens. I believe they are also "case sensitive".
This certainly works for those on an ADSL modem ( I've just tried it again, hence the "AOL Broadband2" name, I've now got two working connections on my desktop, it may be different if you are using a router, I'm not sure.
However, as per router setup, your username and password need to be typed in small letters and your password needs to be 8 characters or less. You also need to add @aol.com on your username.
If your password is more than 8 characters it will come back with a username/password error, so, if it is more than 8 characters, sign into the AOL software and change your password to 8 characters or less.
EXAMPLE:
USERNAME: [email protected]
PASSWORD: myhome5
I've been with AOL for years now, never had much bother with them, despite the bad press they cop. The Tech help is awful, I just dont bother with them tbh. The service however, is pretty good, from my own experiance at least.
I'm on the 8Mb service now, after taking part in the trials for it, and speeds are fantastic. Bittorent speeds are also excellent. No worries there.
EXAMPLE:
PASSWORD: myhome5
