Has anyone fitted a Poweradjust 3 USB, Ultra-version
Here is my setup:
EK-Dual DDC 3.2 PWM X-TOP With Dual Laing 18w DDC Pumps, with heatsink kit ,res top and the ek 250 res
Aquaero 6 Pro USB Fan Controller:
Fan 1
![Stick Out Tongue :p :p](/styles/default/xenforo/vbSmilies/Normal/tongue.gif)
WM-EK-Dual DDC 3.2 PWM X-TOP ---pump 1
Fan 2
WM-EK-Dual DDC 3.2 PWM X-TOP ---pump 2
Fan 3
ower-Top 480 Rad Fans x4 noiseblocker eloops(3 pin)
Fan 4
ower-x2 corsair 120 led fans, 1 rear 140 fan
Fan 1 : 360 rad fans , x3 noiseblocker eloops(3 pin)
I have only just installed the poweradjust, and i am prety sure i have done somthing wrong here.
Before i had the EK-Dual DDC 3.2 PWM X-TOP With Dual Laing 18w DDC Pumps, i was using a single d5 pumpo, long story short, i had tons of probs using jsut 1 pump, restrictive rads ect hardwarelabs balh blah.
Anyhow i had my entire system set up that is was near enough silent. the top 480 rad woudl perm run slow. the bottom rad fans never kicked in until i was gaming or my cpu temps ect went up. in other words it was silent, until it needed more cooling. it was set up near enough perfect for me.
Since having the new pumps and using the power adjuct i cannot get my head around my setup. have i set up somthing wrong here lol ?
Also i thought when you added the power adjust it would put another fan to be controled in the aquareo section. nope i was wrong it has its own section that for the life of me i cannto work out how to set up . it does not have the same options as the aquero, ie temp wise, it looks liek it uses a sep temp sensor.
So i have a feeling i have connected somthing wrong here, i have connected the power of both pumnps to a molex even though i have got x2 pump cables, not sure what to do with them tbh,
any help i would be gratefull
