- 31 Jul 2012
- Cheshire
Arcade console cabinet build log - Project Raptor
I figured this fits into the 'All matters relating to consoles and their games' bracket so I thought I'd post this here; it may give someone some ideas if nothing else. I'm logging it on a couple of other forums as well. If this is not the correct place, please move this thread as appropriate.
So I've already built a Vewlix arcade cabinet for XBOX fighting games ...
... and my son wanted me to build him a machine too. It will be modular in the sense that it will have a base unit and interchangeable control panels. The control panel section can be un-docked and moved out of the way when not in use.
A couple of really bad sketches of what the base unit and control panel profiles will look like:
I need to work on the design of a ‘shroud’ and marquee which will attach to the back of the display. I have some ideas in keeping with the overall design.
Internal Shelves:
Sides:
Basic shape of the base assembled (bottom section will house a console, top section the PC components and speakers):
Monitor legs bolted on and the first top piece cut:
Interior of the base unit skinned (textured vinyl):
Exterior skinned:
Top pieces cut:
Shaped sides added and legs cut:
The legs will sit on some adjustable feet:
Legs not yet attached:
Top retaining section cut and shaped:
The white tube will act as a conduit to pass the cables through.
A new display will be purchased rather than using the current one.
Retaining piece painted and varnished:
T-molding applied to the lower aperture where the XBOX will sit:
Current state with the legs attached (sides are just primed at this point):
I'm currently working on this at the weekends only. Next activities will be to spray the side pieces, design/add some artwork to the sides and then start working on the control panel. Once I have the new display, I will work on the shroud to fit on the back of it which will hide the tubes.
Internal Shelves:
Sides:
Exterior skinned:
Top pieces cut:
