"Many have assumed that Coffee Lake can be supported on older Intel mainboards because of their use of a common socket, but that cannot be further from the truth. Yes, both Z270 and Z370 use LGA 1151 CPU sockets but the similarities end whenever you look at exactly what each pin is used for. "
The socket type is identical thus all coolers should fit by the sound of it![]()
Sorry I totally misread your post.Its not really the socket
Its not the socket i'm concerned about. Its whether the motherboard blocks will fit the same to cool the vrms etc.
Look on coolingconfigurator EK keep that upto date.
Every board is slightly different I highly doubt any monoblock will fit more than one model of main board.
Sorry again!
If you look at the EK tables many of the confirmations just say visual not physical anyway... if the sockets the same and VRMs in the same position the monoblock is good to go.
I already ordered the z270 Apex block because there was only 1 left![]()
Nice I will be fitting my maximus hero 9 block to the mobo tomorrow shall let you know how it goes!
bullshark did you fit the monoblock 2 the hero x yet
keep us up 2 date if it works ok on it stuck with my build for a few week just need 2 decide what cooler i want and get a graphics card but got a pre binned 8700k but its just sat there doing nothing lol
I'm the other way got all the parts apart from the 8700k. Feel free to send yours over
