- 12 Jun 2020
I ow consider the matter closed.
Andarial, I suggest that you nind your own business if you can't understand that the standoffs are suipplies by Artic Cooling in two varieties, one fpor Intel and one for AMD. So please keep youur nose out of it
Furthermore, my motherboard is not compatible with Rev3 - the front plates that are supposed to go on top of the standoffs are simply too wide & they intercept the capacitors on my board. Good one arctic!
blame the motherboard manufacturer not arctic
I enjoyed the friendly banter here and was compelled to create an account and make it my first post.
This is a classic case where everyone is right but no one is really listening to one another..
Anyway, I got the Arctic Liquid Freezer II to pair with a Ryzen 7 5800x on Asus ROG Strix X570-E. After a frustrating & ultimately failed attempt, I realised that Arctic, in their infinite wisdom, have released 3 versions of this product without really making it too obvious.
You need to pay attention to the fineprint over the barcode on the box you receive your product in. For me, I had the 240 version but the actual pumping units are identical across all versions of the unit.
https://support.arctic.ac/index.php?p=lf2-240
I got Rev3, almost all the instructions / installation videos are for Rev 1.
Rev3 DOES HAVE STANDOFFS for AM4 - (Vanilla [Rev 1] and Rev 2 don't, hence the mexican standoff on the previous posts - no pun intended).
Long story short, if you are installing this
#1 make sure you know what Rev you have by looking at the fineprint above the barcode on the box
#2 if your motherboard is not compatible - punch a wall & contact Arctic for the right parts.
#3 keep calm & carry on.
https://support.arctic.ac/index.php?p=lf2-280
Installation instructions for all three versions of the 280 version.
Note that it says some mobos have non-compliant back plates that mess with the mounting, and to contact support for a replacement kit.
Just posted about this in a different thread. Load of play, and the brackets snag on the capacitors. Tried on an Asus and Gigabyte motherboard. Emailed their support and am awaiting response. May try and mount it without the brackets in the style of rev1 and rev 2.
