Artic Silver 5 - strong stuff
7 Jul 2008
Newcastle upon Tyne
bought some Artic Silver a couple of weeks ago for my Ryzen 5800 and AIO.
today I decided to rebuild the pc into a new case. Removed the screws holding the AIO pump and it would not come off. used a bit more force and it came off taking the cpu with it
flippin ek, strong stuff and something I have never encountered before. CPU is fine btw
If you run a stress test to get the chip nice and warm before taking the cooler off, it comes off quite nicely
Pretty common especially with AMD chips, often will pull them straight out of the CPU bracket. Best thing is to get them a bit warm, and if possible twist the cooler off slightly. So many people have bent pins because they pulled it straight out or off and it’s flown across the room!
A hairdryer comes in handy too if you forget to heat it up before dismantling or if it's cooled too much by the time the motherboard is out of pc.
