Article: Nvidia investing in cloud based GPU streaming technology using current Kepler tech
You can pop a decent graphics card for £80-100 into pretty much any computer that can play games at 720p at highest details with no lag.
Now you want to start a rental service instead?
Surely Nvidia aren't going to invest in a system which requires less in the way of GPU power? I speak from ignorance here but this "unique feature" sounds like it will not make much use of the GPU itself, thereby making the sort of OnLive argument: "if it's streamed to your computer you don't have to spend a lot of money on a top end Graphics card". There is the added problem that at the lower/mid end (where such a program may be beneficial) AMD are the brand of choice with their 78xx/77xx series.
The only way I could see this being profitable for Nvidia was if their partnerships with entities such as Gaikai were on particularly favourable terms
HAHAHA this is about my avarage speeds, using newsgroups i max out around 2.5mbs
and im with talktalk llu copper cable 24meg service.....
no caps :D
and even i consider this speed **** compaired to uks fiber optic 50meg and 100 meg services but we still dont have fiber yet :/
you think UK is bad, try Ireland. or south Africa. OMFG.
Its depressing when you need to rent GPU power. where's the fun in that?
+1. I'm stuck on 1.8mb in the countryside. Things like this will be the death of me and I'd go as far as campaigning against it.
no caps :D
24mb on copper? That can't be right, can it? Copper AFAIK has a lot less capable bandwidth than that.
