Yes ( edexcel)
Right, edexcel have messed up big time with that circle in a triangle question. Every one I have spoken to did not get it, it took 4 maths teachers to work it out for god sake.
Everything else in that paper was doable, saw that quadratic rectangle and I thought for 5 minutes that you could use X as the depth and it finally dawned upon me that you could not. Going to be a low grade boundary as that circle question in a triangle was impossible.
Come on guys, be fair! Is it really that unreasonable that on an A-Level exam, there was a question that the majority of people found very difficult?
Yes, what's the point in putting down a question that relies on someone being ahead of the syllabus? I doubt even 1% of the students will get that and it completely throws you when you get a question that you can't do no matter how much revision you have done, I spent a good 10 minutes that could be better spent on checking and after the exam I found out that it is pretty much off the syllabus stuff.
Mind if i ask what the question was?
The fact that you haven't been taught how to answer a question does not make it a bad question - in fact, I'd say it makes it a good question! Personally, I would like an A-Level to require both hard work and talent. Having done lots of revision should not, in my mind, mean you should automatically be able to do all the questions!Yes, what's the point in putting down a question that relies on someone being ahead of the syllabus? I doubt even 1% of the students will get that and it completely throws you when you get a question that you can't do no matter how much revision you have done, I spent a good 10 minutes that could be better spent on checking and after the exam I found out that it is pretty much off the syllabus stuff.
[/QUOTE]
Yea i think i have the answer. Bit mean to put it on an A-level paper though, as it does require a bit of engaging brain..
EDIT: In case anyone's interested (hell it's more fun to write this up than doing more revision :p)
[URL=http://imageshack.us/photo/my-images/11/easytrigonometry.png/][IMG]http://img11.imageshack.us/img11/8554/easytrigonometry.png[/URL]
Basically this is all you need to notice. Then you can just write
r = (6 - r) * sin(pi/6) = (6 - r) / 2
=> r = 2 with a line or two of algebra.
Not one of those questions where you need to "learn a solution", so i suppose it is a bit out of place. Would kill for something like this nowadays though![]()
EDIT: In case anyone's interested (hell it's more fun to write this up than doing more revision)
