- 27 Oct 2013
I see that the PG42UQ is now available on the OC site for pre-order, but theres no info for its ETA, so is there any info on this?
I havent seen that before, and it does look promising, we just need a confirmed release date.
That will be the Asus tax for you and you can get the C2 for £970 currently. will be interesting to see what the reviewers make of it.The problem is it's already at least £400 more expensive than the c2.
The only reason to get this over the C2 is the uniform brightness function, i would love to see how that passive heatsink is implemented though.
The screen is now with me and being tested don’t worry![]()
华硕首款42英寸OLED电竞显示器PG42UQ全面评测报告
本期我们评测的是华硕首款42英寸OLED显示器PG42UQ,4K 138Hz电竞显示器,它采用的是LG Display的WOLED面板,具备0.1ms级别灰阶响应、峰值亮度900nits等特性。评测内容主要针对外观、菜单功能、显示体验(ABL机制、像素排列、游戏、HDR体验)、拆机解析环节、以及屏幕实测数据进行全...www.youtube.com
With auto translate subtitles you can get most of what he is saying.
Still, think I'll be waiting for a @Baddass full review before I order one
Edit:
Ah it's the same as @JustSomeDude posted above, sorry for repost!
If you're budget-conscious and don't mind the glossy finish then go with the C2, simples!Guru 3D review is ok but what I'm wondering is how does it compare to the C2 with the coating and the extra desktop features as its like 40% more expensive
