ASUS AUF mobo with 7900X cpu temps
28 Jan 2011
hey guys,
As mentioned in another post, i have just setup my "new" rig..but the temps are a concern to me.
can someone point me in the right (easy) direction to allow cooler running on the CPU? I know i will loose several percent performace but if it lowers my temps 5-10 degrees, worth it!
cheers.
You can use something like curve optimiser however the new AMD cpus will run at 95Degrees most of the time no matter what you do. I seem to recall one of the youtubers do a experiment and the only way they could get the temps down a little was to delid, liquid metal and direct die cooling with mad water chiller.
thanks. am I ok leaving at those temps though while im gaming??? I came from a 5700X3D and ran cool on my 360mm rad..
so a bit of a change on this CPU lol!
7900x in particular seem to run the hottest out of the 7000 line up, upto 95c is the official limit they can run at, normally in games you should see mid to high 70's, if the action gets intense then it will make the CPU spike.
A friend of mine has a 7900x and like you was concerned about his 97c spike temps so I guided him through how to setup a custom temp target via the bios, after he's seeing mid 70c max spikes and normally low to mid 60's in games.
thanks, I will monitor it and go from there over the next couple days!
What are the temps? You shouldn't be seeing super high temps while gaming, but while using Cinebench, sure.
You can use eco mode, or a negative offset with the curve optimiser, though you also need to power limit because an undervolt will just increase the boost envelope and it'll hit higher clocks :o
It is fine, here's an informative video if you have 20 minutes.
From AMD themselves:
Designed for a lifetime at 95
Before anything else, let’s be clear: All of the quality analysis for Ryzen 7000 series desktop processors was done at 95 degrees Celsius. The chip is engineered to live its life at this temperature with no detriment to longevity or reliability. In fact, this is the same design target we’ve had for a number of product generations, but it has not been until the Ryzen 7000 series that the platform has had access to a level of socket power that makes 95 C the temperature that delivers the most performance during multithreaded workloads…
I was in the same shoes as you are initially after building my first Ryzen based System.
I wouldn’t bother with Ryzen Master as it kept setting a -30 Curve Optimiser for me and was not stable at all.
With my 7600x I simply adjusted Fan Curve (Both CPU and Case Fans) to be far less aggressive to reduce fans ramping up and down dramatically.
The main issue with a Default Curve is anything 70/80/90c tends to demand 100% Fan Speed which by design these CPU’s can run at 95c Safely and will try to Achieve 95c (To maintain and achieve highest possible boost clocks)
I basically created a Fan Curve which draws a line beyond a certain temperature to avoid them becoming unnecessarily audible but enough to keep temperatures in check.
I tried Eco Mode etc etc with my 7600x which worked fantastically but did suffer a slight performance drop.
In the end I settled on -28 Negative Curve Optimiser and reduced Power Limits and Target Temp which dropped my temps, ensured boost clocks are maintained and actually increased performance from stock.
What Motherboard do you have? I could find a Guide which you can follow step by step using the same BIOS to make it a little easier if you aren’t familiar.
I’m not an expert by any means, but after research and echoing advice this seems the way to do a quick and easy undervolt on these CPU’s.
will have a look at that, thanks Tetras.
Please. My board is Asus TUF GAMING B650-E WIFI.
Same Motherboard as me!
This Video is Explaining the Steps on your exact BIOS so everything will be like for like.
I generally reduced Fan Noise by 50% and Temps Significantly.
I can’t remember if I even bothed with Temp Limit as it was a while back but I can check and update in an hour or two.
lol, what are the chances..
thanks mate, will have a wee look at that. Thanks also @Tetras for the vid too!
@Gilbert89 did you do -30 or did you try like -15 / -20 first...
im just paranoid I break something, I hate the BIOS ! :cry:
I was like a cat in the headlights as it was my first Ryzen CPU and have been out of the loop for many years so I initially used Ryzen Master Software which runs a test to determine what is achievable for your CPU which dialled in -30 but this had instabilities since I experienced crashes in BF2042 after 5/10 minutes of Gameplay.
I then decided to apply the Negative Curve Optimiser using the BIOS by setting a -20 which gave me no issues then on to -25 again no issues before fine tuning to -28. (Being Happy with Acoustic's and Temps I left it there and have had no issues since)
Perhaps just try the Curve Optimiser and Fan Curve before seeing if you need to go further adjusting Power Limit, Temp Target and so on as this should improve things in general gaming application by a fair margin.
yes, thats what i will do. heading off for the night so will tackle this tomorrow.
thanks again mate. will keep you updated! :)
No worries - The YouTube I linked does cover it rather well and shows before and after results therefore if the steps are followed you should achieve what you set out to do.
After spending a decent amount on a new build I was somewhat deflated with the Fan Noise and Temps but after creating a suitable Fan Curve paired with the Undervolt it is now virtually silent compared to Stock.
Quick update,
Just went to the BIOS and set the AMD ECO MODE to 105W TDP..just testing out now..
105w eco mode will drop temps significantly but also your boost clocks will be a fair bit lower, gaming should be ok but cpu heavy work loads will suffer a bit.
105w eco mode will drop temps significantly but also your boost clocks will be a fair bit lower, gaming should be ok but cou heavy work loads will suffer a bit.
Yeah, I watched a gamers nexus video on that, and performance a wasn’t too bad multi core , and I know it’s not the best chip for gaming, but 90% of it will be for gaming anyways…
The non-X was my choice as I wouldn’t be okay running a CPU at 95C 24/7, even if it is intended to do so, according to AMD. Running on Eco mode you pretty much turn the 7900x into an 7900. And turning PBO will pretty much turn the 7900 into the 7900X, but will be few exceptions.
On another note, the fact that the newly released 9000 series doesn’t boost to 95C as standard makes me wonder if that behaviour was a good choice to begin with.
