ASUS RAMPAGE III EXTREME MOTHERBOARD AVAILABLE TO PRE-ORDER
17 Oct 2002
Stoke
Here's the latest motherboard you've all been waiting for extreme overclocking on the latest Core i7 LGA1366 Platform.
Asus Rampage III Extreme Intel X58 (Socket 1366) DDR3 Motherboard @ £329.99 inc VAT
Asus Republic of Gamers reveals the latest addition to their roster of performers, the world-record shattering Rampage III Extreme. Delivering Intel's X58/ICH10R chipset with support for the Intel processors in the LGA1366 package up to six cores and a plethora of features demanded by intense users, this board is the only choice for PC speed demons. Remote tweaking becomes effortless thanks to built-in ROG Connect and RC Bluetooth, giving users the freedom to unchain true hardware potential. Rampage III Extreme contains the latest iteration of Extreme Engine Digi+ voltage modulation technology for purer, more stable power. The OC Kit strikes a formidable pose as an interface to meet the strenuous requirements of even the techiest overclocker, with LN2 mode and a Q reset that addresses cold boot problems and enables fast operation even under very low temps during extreme overclocking.
- 2x USB 3.0
- 2x SATA 6Gb/s
- CPU: Intel Core i7 Processors (Socket LGA1366)
- Chipset: Intel X58 Express / ICH10R
- Memory: 6x DDR3 DIMM 2200(OC) / 2133(OC) / 2000(OC) / 1800(OC) / 1600 / 1333 / 1066 MHz (Max. 24GB) / Tri-Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 4x PCIe 2.0 x16 Slots, 1x PCIe x4 Slot & 1x PCI Slot (Supports ATI CrossFireX & NVIDIA 3-Way SLI Technology)
- Storage: 7x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 1x eSATA 3Gb/s
- LAN: Intel Gigabit LAN
- Audio: 8-channel High Definition Audio CODEC
- Bluetooth V2.0/V2.1+EDR Card
- 9x USB 2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- 1x S/PDIF Out (Optical)
- Extreme Engine Digi+
- USB BIOS Flashback
- ROG Connect
- ROG Extreme OC Kit
- Extreme Tweaker
- iROG
- ProbeIt
- ASUS Q-LED
- Loadline Calibration
- Q-Fan Plus
- Extended ATX (305.0mm x 269.0mm)
Only £329.99 inc VAT.
ORDER NOW
What's the cooling like on this board? Would you need to go full water cooling (nb/sb etc) if you wanted to pair it with a i7 980?
this is even more tempting now there is a price but its a shame to put anything less than a 980x on it hmmmm *ponders really upping ones budget*
Oh darn, I did preordered it, but now it seems my Antec P182 doesnt support EATX :(
I'll look for a new case.
Check my review, it fits fine in my mid tower Lian Li B25. Just check if you have an extra inch spare. It's not a proper eatx motherboard, just one inch wider.
I do have an extra inch, I measured that out before, I just dont have ful EATX support.
Think i need to read some more reviews before i commit.
Quick look at making a new video editing machine (but keeping the one I have already) makes for a £4k computer lol........
/cry I just know I will probably end up buying it and falling out with the wife again lol
How many are you likely to get on launch?? Do you think it will be pre orders only?
Ok, thanks for clearing that up :)
I have right around 3 cm / 1.25 inch extra space, which is enough width for 274 mm.
So I'll just have to be careful putting it in.
Yeah! I didn't realise how big it was until I starting installing it and wondered why it wouldn't go in as easily as my other board!
You can imagine I was pretty horrified but in the end it did fit after moving a few cables around :).
Tee hee, sneaky edit, I say 275 mm now, not 274 :p
Dont need a new case, phew.
Also I'll have to put my new DVD drive into the top slot to provide more clearance.
