No wonder marketing keeps inventing fancy acronyms, because neither looks that great:
One has under exposed shadows, other over exposed highlights.
Guess that's same as in when someone takes ****** pictures, they call those art pictures.
I'm sorry to hassle you @NikTheSHNIK . Other vendors have no clear ETA on this, any news from your end? Even down to a week range, or is it still not clear?
Got 5 or 6 units arriving next week hopefully (w/c 05/07/21) and then another 10 or so a week or 2 later.
The first 5 should cover orders up to the 18/06.
Take with a pinch of salt as haulage is crazy at the moment.
Fingers crossed! Especially as a certain devilishly handsome customer ordered around that date....
I take it no Haribo this time cos haulage!
Mine arrived this morning - really impressed with it! I moved from a27" ASUS predator 1440p 144hz IPS monitor.
Out of the box it has the firmware that supports Freesync over the displayport, so no need to update the firmware for that (I'm using a 6900XT and VRR range for freesync is reported as 1-144hz). I looked at the HDR videos referenced in the tftcentral review and they look amazing. Yes if you look for blooming on the christmas lights video you will see it - I didn't notice it at first and only spotted it when looking for it. The other thing is that the blooming only takes that area of the display to the same contrast you'd get from a non FALD display, and it is limited to where the lights are, so in my opinion it's good.
Running the UFO test the blur isn't anywhere near as bad as I'd been led to believe. Is it there? yes. Is it noticable if you're not looking for it specifically? not in my use/testing so far. I'll come back later with more thoughts but out of the box I'm super impressed!
The OLED has an annoying logo flash across it even if you only want one stat to be shown. They need to release an update to turn that off as the motion on it is distracting.
As an aside holy hell windows have made it hard to get to the setting for monitor refresh rates. Defaulted to 60hz and had to dig and dig to find the option to enable 144hz.
Edit
Found a dead pixelHopefully will be able to fix it as my old monitor had none and I won't be happy if a 3k monitor has dead pixels that I can't fix.
Can’t remember but is that even selectable in that mode? I’d recommend leaving at default anywayWith hdr content what does every one have the contrast level set too?
Yea when In hdr peak brightness says 1400 nits but contrast at 50 which can be moved up or down. When moved up the screen goes much brighter, I’ve put mine up to about 75 and it looks awsome but didn’t know If I should.
Anyone else running this with an AMD GPU? I'm desperately looking for someone else to confirm if having 144hz and Freesync enabled at the same time with an AMD GPU causes the grey screen freeze when loading high FPS games, but as these are so new I can't seem to find anyone with that kind of combo.
