Man of Honour
- 8 Nov 2007
- Outer Space
Probably missed it but what were the original temps?
I belong to the club.... i knowYup, why I said welcome![]()
You still got time to put a order in for a 2080ti before they launch. haha![]()
Yes because a Asus repair engineer won't notice the changed thermal pad once they crack the card open.Unless you use the pliers trick to get the screws out without piercing the stickers![]()
Well Boom you held out a really long while, before buying a new gpu. haha.
Yes because a Asus repair engineer won't notice the changed thermal pad once they crack the card open.![]()
I was pulling your legEh? Why was I holding off buying a new one? That's literally what I do xD
I did have to let one go when I had massive car expense lol. That's sorted now though.
Ha, na I won't go Nvidia 2### series. Prices are for fangirls only. If the price ever comes down maybe. Or grab a used one from mm xD
Why would they open it if it's faulty and the stickers are still in place? It will get tested and then thrown in the skip if it doesn't work.
Plus the pads aren't glued down so they stay in place when you pull the heatsink off. So you couldn't even tell if it's been removed and put back on.
So you really think they throw away a perfectly good GPU if it has a minor fault that can be repaired in 5 mins with a soldering iron.![]()
It cheaper to just send a replacement than spend hours trying to fault find and repair it. I doubt they pay electronics experts to sit there investigating every faulty card which is sent back.
I would think they have a set time/cost to find out the problem with each item and then after that time/cost they throw it away or throw part of it away.
Nice fix, I was actually really tempted to get a Vega 64 Strix but ended up getting a 1080 Ti Gaming X for only a bit more.
