Hi, out now http://ati.amd.com/support/driver.html
Chris
Chris
InterestingCatalyst 8.1 introduces MultiView™ support. This feature provides for hardware accelerated OpenGL rendering across multiple graphics adapters. MultiView™ will provide hardware accelerated 3D rendering in a system containing multiple graphics cards on an extended desktop arrangement. This feature will allow for the rendering performance and additional frame buffer resources to be evenly shared with the second and third graphics adapters. This allows for a 3D application to have the same performance running on a secondary or third display device as if it were running on the primary display device. This feature will be supported under Windows XP (32 and 64 bit versions), Windows Vista (32 and 64 bit versions), and the Linux operating system.
no agp fix from the look of it.
and there never will be so get over it
well they have stated here that they will fix the issue:
http://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=31542
but as you say i shoudl not expect anything from them now, so best thing to do is never buy an ati card again for me. they don;t support me, i wont support them.![]()
That page has hotfixes for 8.1...?
