Looking forward to getting iOS apps running on this, it might actually be worth buying if you could put iOS on it fully functional
It manages just fine with 1080p files
Not 100% sure but I'm guessing so.So it downscale it?
Yes and yesSo, once jailbroken, does XBMC just run as an app on the ATV2 and, if I want to make use of the standard Apple functionality, I can still access this?
EDIT: Oh, and does XBMC do proper 24p playback of MKV files?
Cheers. Actually have a full PC in the living room doing HTPC duties but I'm tempted to get an ATV2 just to play with tbh
EDIT: Hmm, I'm reading that the ATV2 doesn't support 1080p playback - is this true and, if so, does XBMC allow this once installed?
No it doesn't support 1080p output. It will play 1080p video but it will be downscaled via hardware, so running XBMC won't help in that respect.
Completely useless because it doesn't support 1080p - what system are you running?
What happens when you want to watch TV broadcast at best in 720p?
