- 19 Oct 2002
- Shakespeare’s County
If you notice start stop it what defines if you have a premium car or not, forget soft touch plastics.
Then I hope you're the next **** that gets crashed into when your lights blind someone.
Seriously, if you don't care enough to even consider other peoples' perspectives on things, and how you might be causing a serious problem, then that is the sort of fate you deserve.
Not even worth replying to that.
Then why (or even how) is it 'auto' hold if you're controlling it?
Bearing in mind you yourself were mentioning a few posts back how you were doing one thing, while your car decided to do another... That doesn't sound completely in control of the decision process.
Except that you're not the one deciding when they do or don't happen, or when they get released/turned off... That is, after all, the point of auto functions - For the car to detect something and reckon it should be doing X, even if you're trying to do Y or Z.
Who decides when Auto-Hold activates? You or the car?
What are you doing holding the brake pedal while sat in traffic? If you're stationary for any period longer than a few seconds, you should be using the handbrake and keeping your foot of the brake anyway.![]()
Auto hold function off:
1. With the car in Drive, stop car with the brake pedal.
2. Release brake pedal.
3. Car creeps forward, like any other torque convertor transmission.
Auto hold function on:
3. Car doesn't move. The car automatically keeps pressure on the brakes (via the electronic parking brake) to hold the car still.
I did go to Spec Savers, and also have regular enhanced vision tests as I work on railways. My vision is almost perfect. Not quite 20-20, but very close.should have gone to spec savers... infact why are you driving consciously with such a visual impairment. Section 59!
Not true - In your own words, you first have to enable the function in the first place, and then you have to "1. With the car in Drive, stop car with the brake pedal. 2. Release brake pedal".Definition of automatic:
1. (of a device or process) working by itself with little or no direct human control.
"an automatic kettle that switches itself off when it boils"
So this case, the car is applying braking force, without me applying force to the pedal. So it falls under the very definition of the word.
So that's two conscious and direct actions required from you before the function will operate, and at the end of the day it's essentially just an inert holding catch. Nothing 'automatic' about it at all, based on your own definition and description.
So when I press my accelerator pedal I’m not actually turning the wheel with foot either ?Turns out machine guns aren't automatic because you have to pull the trigger.
Should have done some research m8I thought my dishwasher automatically cleaned my plates but it doesn't as I have to turn it on and select the programme![]()
creep on dsg cars is implemented by slipping the clutch no ? , whereas auto hold, for dsg, presumably puts it in park, so should be more mechanically sympathetic/preferable ?
[brake lights are too bright now, though, agree -
in a manual, even if it's in neutral, I keep my foot on the brake if its a risky location, otherwise you're less visible, genetically disadvantaged, than folks where lights automatically stay on ]
That is the standard at which no corrections are deemed necessary, so yes it is generally considered "perfect", even if your vision is beyond that measure.20-20 is perfect vision ?
So?It's literally called 'automatic hold'.
You setting a mechanism and then doing something to trigger that mechanism does not make it automated.You drive the car normally and if you stop it automatically applies the handbrake until you then move off. It is the definition of an automated function.
I used your own definitions and descriptions, so any discrepancies you might have over meaning are down to your own specification.I think Simon was right. Give me a shout if you want to stop feigning ignorance over basic transmission functions, or what the word "automatic" means, and I'll be happy to discuss further. Until then, I'm out.
Turns out my oven is fully automatic, because you don't have to manually heat the food with your own hand.... !!Turns out machine guns aren't automatic because you have to pull the trigger.
