SkodaMart
SkodaMart
The only time I would consider an auto is if I needed a hip replacement or something.
The only time I would consider buying a car with power steering is if I needed a hip replacement.The only time I would consider an auto is if I needed a hip replacement or something.
Any advantage is countered by being blinded by all the auto drivers sat in front, with their foot on the brake and their overly bright LED lights.I would say an auto comes into its own in city driving, stop start.
I'm pretty sure you steer that with your hands... That is how countersteering works, after all. If it were hip-controlled, I'd not be able to rise up on the pegs and moon the riders behind me!edit: before you say you do, I do too.
It’s called a motorbike.
Presumably there's also some muscle wastage on the now-unused left leg or something, too..
I know. How those cars were approved for UK roads, I don't know (but can guess)...Don't worry about muscle wastage, my car displays the brake lights when I am stationary even if my foot isn't on the brake and the car is holding me using the handbrake. Many other cars also do this. There is absolutely nothing I can do about it.
So you go to shift your bodyweight... and the first thing that moves are your shoulders, which magnify and transfer that movement through your arms to your hands on the grips, thus counter-steering. Many riders think they steer by leaning or putting knees out or something, but it's all just countersteering when you actually look at the movements.nope, I just lean mainly.
Counter steer to swerve or adjust my line
That's interesting - I didn't actually know that some cars do this. I'm not sure why - apart from to warn that the car is stationary?Don't worry about muscle wastage, my car displays the brake lights when I am stationary even if my foot isn't on the brake and the car is holding me using the handbrake. Many other cars also do this. There is absolutely nothing I can do about it.
Annoyingly, you have to enable auto hold by pressing a button each time you get in the car.
Porsche is the same activation method as Mercedes, i really like this way of doing it which may come from years of driving autos without the feature at all. I dont actually want hold most of the time as i am edging around in traffic or parking lots just edging around on the brake, but when i do want it, you just jab the brake when stopped. Ive also got a BMW with auto hold and have this same annoyance, it just isnt nice to use, so generally it never does get used.Can confirm, ours does this too.
Annoyingly, you have to enable auto hold by pressing a button each time you get in the car. I'd much prefer the system I experienced in a Mercedes about 10 years ago, where you simply pushed the brake pedal harder and auto hold would be enabled, then you could remove your foot. There are times when I don't want to car to autohold, this seems a more elegant solution than having to press a separate button.
e: on topic: this doesn't avoid the lights staying on though![]()
I have the same grievances with auto stop start. I hate this feature. Same reason as you, it cuts in (or should that be out) just as you are about to move off, or cuts in (out) when you just stop for slightly longer than a moment at some lights which are about to change.
Rubbish rubbish feature. Thankfully codable.
