A couple of weeks ago I upgraded my av receiver, although still probably and rightly so considered entry lever gear the Onkyo TXNR676 was a massive improvement on the older and cheaper Pioneer vsx-323.
The speakers I'm currently using are a Tannoy TFX set although I have replaced the sub with a Cambridge Audio SX120. I have read about matching certain speakers to certain amps etc and i'm wondering if I can get a worthwhile upgrade by maybe changing my centre and front speakers .
When I first set the onkyo up I noticed a massive improvement in sound , everything just sounded better, music,normal tv,football, watching films you can now hear more things if that makes sense and levels seem better ie dialogue is clear now as before you'd have to turn it up really loud to hear speech.
So although the tannoys aren't the best speakers in the world the onkyo made them sound a lot better then they did with the pioneer, I've been looking at centre speakers at around £150 and then stand mounts for L and R front about the same price ,just unsure whether it would be an worthwhile upgrade and the difference would be negligible.
The centre speaker sits directly on the fireplace the tv is wall mounted just above , the left and right speakers and about 2 metres either side wall mounted in alcoves which are about 1200mm wide by 400mm deep.
