AV unit cooling help needed
not strictly for an AV unit but I did something similar for my (closed door) server cupboard:
In and on by neilgates, on Flickr
2x 80mm inlet fans towards the front and 2x 80mm exhaust towards the back fans (to get air flowing into and out of the devices in the right places) powered from a HP Microserver.
flickr set: http://www.flickr.com/photos/neilgates/sets/72157633296476212/
dont know if that helps.
Cheers Neil, that seems sensible. I do happen to have a Microserver as you can probably see in the image so I may run the fans off that. How do you control the fan speed as I don't want them spinning fast all the time?
i dont, the fractals are very quiet even at full speed. i made sure i got quiet fans for that reason.
i was debating getting another aquaero for shutting the fans down until needed.
I think that's what I'm going to do tbh, seems the easiest!
Neil what have you used on the outside of the fan holes to tidy them up? They look smart!
