Into as clear an area as possible. It's just so that the card can get a better signal to the router.
i mean do they stay on the inside or outside the case?
You have got to understand, these guys do not need to give you advice. They have done this more than once and will not tell you bad advise.
I've only built 2 or so PCs but learnt almost everything I know from these guys without actually having to ask them. Search the forums a little and see what other people are being recommended. I bet it's quite similar.
In all honesty over the last couple of days most of the reputable "speccers" haven't been online much and I've seen some pretty poor advice being given
cheers hono, and i know its my 1st build I'm just confused, you've got to understand im going to be spending £600-700 on a complete risk if it works or notbut i think ill go with the 7850 option u listed 1st and i already have the 120gb ssd and 500gb mechanical drive orderd, and ill get an os with my student card i think you get mad discount at currys
Hono its worth noting you may have some space problems with that GPU as it is 3 PCI slots deep not the usual 2 slotI know it can affect regular ATX mobo's not sure what effect it will have on ITX ones?
Well spotted though.....this is what happens when we spec at silly o'clock. As I said even the best of us can make mistakesThe Gigabyte one? Nice![]()
Btw Happy Christmas![]()
i havent actualy orderd a gpu yet... orderd everything else and im sticking to it now i went with everything else you told me im just holding back splash £100+ on something i dont know i need as i was looking on the recommended gpu's for arma 2+3 and it says gtx 260 or 5770 (the game runs mainly on cpu its not got great textures and such just huge maps) so I'm going to do a bit of research myself and see what works good enough and save some cash that way, if any1 could recommend something cheaper than a 7850 i would appreciate it
Honestly just get a 7850, it's a pretty low-tier budget gaming card as it is, and Arma 2 won't run too well on anything lower.
