They can fit 10 spools per 45L box...
I started with the cereal box, but it took up too much space...
But got a cupboard where the electric meter is and is wide enough to fit 5 high 45L Ikea boxes in...
This is like what I have, and I have silica trays at Botton 2 per box...
makerworld.com
makerworld.com
makerworld.com
This is what I use for the Ikea 45L box...
Trådförvarare: Dry Box Spool Holder IKEA Samla 45L by jr2142
I came up with this dry box holder after using 22L Samla boxes for a while to store my filament. Here are the advantages of using a 45L Samla box instead:It fits up to 10 spools compared to the 8 spools in 2x22L boxes while requiring the same spaceFilament swaps are less of an hassle as the...
IKEA Samla 22L / 45L Silicate Box Remixed by KommEierKraulen
Dieser Remix basiert auf der Cheetah Drybox. Aufbewahrung von regenerierbarem Silicagel in Kombination mit der beliebten IKEA Samla 22-Liter-Box und der IKEA Samla 45-Liter-Box + Klemme für die Drybox für die 22L Variante. Folgende Filamenthalter werden hier benutzt: 22 Liter ThomaS45 Liter JR2142
Ikea Samla 22l Clip - Never Lost by Generics
SummaryAnother simple Clip for your 22l Samla Box with or without sealing. Just a satisfying “Click” and closed.Use a strip of double-sided adhesive tape (showcase on the pictures - red stripe) and you are done with searching your Samla Clips.I used this one...
