Man of Honour
- 17 Feb 2003
- Chelmsford
When it comes to buying water cooling equipment, what size barbs should I select?
1/2" barbs with 7/16th Masterkleer![]()
Pump
DDC ultra 18w with Alphacool top
Low Restriction System
XSPC Reservoir Top
XSPC Standard Top
EK X-Top G1/4
Koolance Top
Petra's DDCT-01s Top
EK XRes-140 Reservoir Top
Danger Den DDC Top
Alphacool Top
Alphacool Reservoir Top
Stock Top
Does anyone have a .pdf template for the 120.3?
Just out if interest why do you recommend the Alphacool top over the EK, XSPC or Petras?
The components you spec'd out are all very low restriction ones (Fuzion and PA120.3)... I don't know if you have already seen it but have a read of this, especially the Performance Ranking Table.
http://www.martinsliquidlab.com/DDC32PumpTopTesting.html
The Alphacool top is essestially the worst choice of top for a low restriction loop.![]()
Sorry for assuming you were involved with a WC shop - I must have you mixed up with someone else.
