Cheers Elric! Thanks for your advice. What size tubing would you have to get, would it have to be same size for both the tubing and compression clip? Or could the compression clip be bigger?
The compression kit I used was that Innovatek stuff, so it was 10mm tubing with 8mm inner bore. I know you can get larger bore compression fittings, think it's Koolance that use the larger stuff.
It would be nice to see some more larger compression fitting available for the 7/16 & 1/2 types though. If you want to use compression fitting, use the correct tubing size for the fittings, smaller tubing is not woth using as it'll be a sod to get on and off, and defeats the purpose of the comresiion fitting anyway, the compression fitting locks the whoe thing together.
