you should be able to deilid as they use the same tim as devils canyon.Anyone de lidded one yet???
Or are they soldered,doubt it tho,so come one who will be first to chop it
Pretty much all 5820k will hit 4.4ghz. All that seems to vary is how much volts and hence heat it needs. I got lucky. Mine does 4.5 at 1.25v and I haven't really played with it much to see if it goes even lower on the volts. Total rubbish about the turbos. All my cores run at 4.5. I think he's talking just about at stock.
From what I've seen with stress testing, they're still hitting the 80's-90's so id say pasted again.
Damn, Pasted and uses a thinner PCB which someone has already killed with the vice only method![]()
Fantastic read. Happy with my current system as is so wasn't intending on moving to Skylake anyway but, definitely wouldn't now. I can't afford an X system (nor do I really need it) so don't envisage a serious upgrade for a few years, at this rate.
All 5820k I recently tried can do 4.2 at 1.2 on basic air.
All 5820k I recently tried can do 4.2 at 1.2 on basic air. For 4.5+ in general u need water but the IHS is soldered so no delid.
The maximum, minimum frame rates 4.2 5820 vs 4.5 6700 was within 2fps when I tried on bf4 and crysis 3 with 970 at 1080p
I have delided about ten of these 6700k CPU. The paste in my opinion is simply awful. On ln2 pot temp -186 I have seen a CPU throttle at 100+ with 1.65v. Really junk TIM.
5930k hit and miss I think. I tested like 10 or so two weeks ago. 1x 4.7-4.8 , 3x 4.6, 3x4.5, 3x4.4 testing 1.25-1.3v all testing on water.
