Hey guys,
Just going over an old exam paper, and theres a basic trig question which i really cant remember how to do, basically just working out the length of a side and an angle
I was given the 2 sides, and the 28 degrees angle. I worked out the other angle by 90 - 45 = 17 degrees, which i think is correct? Then as you can see I used both Pythagoras and trig to work out the side a, which didn't work as they both give different values. Any ideas on what ive done wrong
Thanks
Jack
Thanks
Jack
