I missed the "for degree" bit...KaHn said:For Degree I would expect it to be a bit harder than pythag and basic tri tho.
My working is if you dont use a 90deg triangle.
Right angle triangles is just pythag, so you're probably right about that being the assumption to make.
Only if they're in a good mood, surely?KaHn said:Aslong as you state your assumptions he will have to give you marks for working.
KaHn
