WHy am i getting like under 20 fps on Batman. I have 8 gig ram Q6600 clocked at 3.3ghz. Is it that PhyX crap Nvidea are pushing ? All settings on max, do i need to change this ?
It was PhysX ! Totally killed it. Not dropping below 60 fps now with v syn. Spretty good looking game like, So what am i missing with physx being turned off then ?
I'm pretty hacked off really - bought the game thinking the PhysX content might be worthwhile, but it carps all over the frame rate even on the lowest setting and all you get is a bit of paper fluttering about. That's with a high-end Nvidia card. Nvidia = fail.
My cape and paper moved on an ATI 4870. I think it's more like the air around fans and such like (by which I mean there's like a light fog around some of the fans which doesn't appear).
Can't say I feel I've missed anything with PhysX off.
I've played with it ON and OFF and I have to say, you really wouldn't miss it.
The only time I sat back and thought "oh..my...god" at the physx was in the scarecrow sections. Mainly cos one particular event caused my PC to bleed =p
More to the point is why am I forced to Install PhysX software to run Arkham Asylum, I don't need it and I don't want it. Just another piece of useless software if your running an ATI card
Obviously it's to make you aware of PhysX so that the next time you upgrade you want a card that supports it - which is only NVidia then they make money.
