OK it was only £1 and change but the thought is what counts right
and partly due to my SN margin which is dropping as low as 1 after dark.
Line Attenuation 29 db 6 db
Noise Margin 6 db 5 db
How has everyone been faring tonight? My upload has been a total mess since Saturday night, hovering around 400-700kbps instead of 1.2mb. My router has been heavily disconnecting/reconnecting all day today. I'd estimate around 20+ times.
I've been told that some transatlantic line between the UK and USA was severed resulting in isp issues for a lot of people. No solid sauce for that though.
My o2 connection activated today.
Tried using the o2 box initially, found the signal hopeless, thankfully getting things working with the Netgear DG834G was dead simple and my signal strength is perfect.
I'm on the up to 16meg service here is my stats:
DownStream Connection Speed 15639 kbps
UpStream Connection Speed 1187 kbps
Sync speed is great, am I right in thinking my noise margin is rather low?
Previously it was 10db (attenuation was 25db) I wasn't expecting these to change - I guess since its LLU my data travels a different route?
Download speeds seem a bit "incosistent" and seem to fluctuate, could this be due to noise?
Nevertheless, my speeds are still at lowest better than what I was paying twice as much for previously.![]()
Your line atten is that 29db up and 6db down? I didnt know the numbers could be so far apart. Mine are..
Cheers guys, one more question, since I'm syncing at down at 15974 kbps does this suggest my line wont be cable of 16meg+ speeds? Wasn't sure if that was the equivalent of "maxing out" the 16meg service or not...
I believe that is the max sync you can get with interleaving turned on, which it will be as your a new customer. So you should beable to squeeze some more if you had a 24mb product. (pretty sure having interleaving on takes a very small slice out of the max sync, someone correct me if im wrong)
