OcUK Staff
- 26 Nov 2014
- Stoke
We are happy to introduce the brand new Lian-Li Alpha 330 and 550 cases. Available in Black or White, they are Lian-Li's first major foray into the tempered glass & RGB market. The 330 is a compact midi tower featuring tempered glass on the front and side panels, with a distinctive diamond pattern on the front panel. It can support E-ATX motherboards, 360/420mm radiators at the top/front of the case, 400mm VGA cards, 170mm CPU coolers, 250mm ATX power supplies and even comes with space for vertical GPU mounting using the vertical PCIe slot brackets. There's a USB3.1 Type C on the front I/O for high transfer rates from a compatible device and there's space for up to 7 fans, with a 120mm unit pre-installed in the rear. Basically, there's a lot of features available for the price.
The 550 shares most of the features from the 330, but is also equipped with 3 of Lian-Li's new Bora RGB PWM 120mm fans, with 16 individually addressable RGB LED's, an aluminium frame and a double ball bearing design for extended lifetime. Alongside this, there is also an addressable RGB LED strip below the I/O, which can be controlled through the integrated RGB controller, along with the fans, using an infrared remote control, allowing over 300 dynamic lighting effects. For those who love RGB, the 550 is an attractive prospect!
As it's Black Friday, we have arranged a preorder deal for both the 330 and 550. Anyone who preorders before the stock lands (will be late next week) will get the following discount on the usual RRP: -
330 - £25 discount
550 - £30 discount
The discount is preloaded onto the cases already, and will be set back to normal RRP once the stock lands, so if you're wanting one, get them on order now!
Lian-Li Alpha 330X Midi Tower RGB Tempered Glass Case - Black @ £79.99 inc VAT
The Alpha 330X housing is a particularly affordable midi tower from the renowned manufacturer Lian Li equipped with many tempered glass elements and sophisticated features.
Was £104.99 inc VAT.
Only £79.99 inc VAT.
ORDER NOW
Lian-Li Alpha 330W Midi Tower RGB Tempered Glass Case - White @ £79.99 inc VAT
The Alpha 330W housing is a particularly affordable midi tower from the renowned manufacturer Lian Li which is equipped with many tempered glass elements and sophisticated features.
ORDER NOW
Lian-Li Alpha 550X Midi Tower RGB Tempered Glass Case - Black @ £124.99 inc VAT
The Alpha 550 housing is a midi tower with a particularly good price/performance ratio from the renowned manufacturer Lian Li.
Was £154.99 inc VAT.
Only £124.99 inc VAT.
ORDER NOW
Lian-Li Alpha 550W Midi Tower RGB Tempered Glass Case - White @ £124.99 inc VAT
The Alpha 550W housing is a midi tower with a particularly good price/performance ratio from the renowned manufacturer Lian Li.
ORDER NOW
330 - £25 discount
550 - £30 discount
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
