Beard Trimmers
What one did you go for in the end? What's your thoughts?
That Phillips is the same one I got a few months ago. Stay away if you don't just want a clean shave. The guard is absolutely useless which means at whatever length it's set at it doesn't actually cut.
it may be fine if you want the three day look and you trim every day but if you want any length or trim relatively infrequently then it just doesn't work. Works fine with the guard off though, not far off a razer shave...
