Yep thats what I did in the end, so its not an issue now. I'll take another look sometime though.Its not unusual for that to happen, I've had a couple of PC speaker systems that at the extreme low volume will only play via a single channel. I just turned the windows volume down to compensate having the volume on the speakers a little louder.
It's on top of the sub, unfortunately.
That's not good for £100 pc speakers.
Good man, great starter system when moving up from pc speakers. Next step will be hi-fi separates, then you will want big floorstanders and a pre/power amp combo in no time. You wallet will hate you.
As long as you don't go for the razers then it's all good. For that money you could have the z5500 which are very good value for a 5.1 system. But they arn't soo good for music, just too much bushy bass and piercing highs, with no midrange.
Have a good xmas and I hope santa brings you the AEs![]()
They're not too good I've found...Sticking to the original post (no budget given):
M-AUDIO BX10S subwoofer
and some BX8a Deluxe active monitors.
