I have the Nzxt Kraken X52 it's OK i had to add two additional fans and make it push/pull for the performance to be good though.
I think corsair are about to bring out a new one may be worth looking at?
They're pretty much all the same, I had a predator one which was very good but kept leaking.
Maybe hold out for black friday deals?
Which do you want, a CLC or an AIO? All CLCs are a sub-group of AIO, but not all AIOs are CLCs. CLCs are factory sealed with no provision to change, fix, repair anything or even top up coolant. AIOs that are not CLC have copper radiators, real threaded fittings, a fill port, and can be serviced and repaired as needed.Yo guys,
I currently have the NZXT x1 and had it for years, think she is starting to die on me so thinking of a new one. Any advice on which is best? or just get the newest NZXT?
Good AIOs are a little more money, and while still not as good as a nice custom loop are way better than CLCs are.
Yeah, that is a CLC for sure. Just curious, how long have you had it and what kind of temps does your CPU normally run?Hmm... well i'm guessing my current one is CLC, with the NZXT X1 its just plug and play. At most i need to re thermal once in a while. So wanna stick to that.
Not really high temps but it cold be wearing out / be getting low on coolant after 2-3 years. If filters haven't been cleaned in awhile it's probably time. I clean mine every time I clean room computer is in .. and inside of computer stays clean because all air going in is filtered. If your air is not being filtered, remvoe fans from radiator and clean radiator fins.Had it about 2/3 years, not sure to be honest. Normally idles in the 30's and mid 60's for long duration gaming. Normally when it starts hitting 70's+ i re-thermal the paste and clean the fans. But it hit 78 the other day and just feel its maybe about time for new one. ( any excuse to spend money )
As old as it is it might be worth at least having a cooling setting on the shelf in case it does fail .. because when it does it will likely stop working at all so system won't be usable until new cooler is installed.
I have a alphacool 280 cpu and it's great. It has a refill screw, and I connected it up to a Alphacool Eiswolf 120 GPX Pro Nvidia Geforce GTX TITAN X Pascal.
It's very simple to connect together. And by doing it that way I have 2 pumps![]()
Hmm, interesting. I haven't seen this one before. Will give it a check but got to be honest I like the simplicity of the NZXT/Corsairs where you don't need to change or really maintain them. I'm lazy![]()
As someone who knows very little about liquid cooling, that does strike me as a bit of mistaken thinking. It's not that they don't need to be maintained, they do, it's just there's simply no option to do it, so they die.
Best in my opinion is Swiftech AIO but it's hard to find outside of USA. As said above, Alphacool make some but I would suggest you check out their customer support history before deciding to buy one.This is true, never really thought about it to be honest. Ok, you have my attention on this, If i'm to get a non CLC cooler. Where the best place to start and recommendations?
We are not supposed to post prices from other places on OcUK.Had a little shop around i can get SWIFTECH H220-X, any thoughts on this one?
Oops, edited it out.We are not supposed to post prices from other places on OcUK.
At this time I think Swiftech is the best AIO made. If Alphacool had a better rep their AIOs may be a good option, but after hearing some of the horror stories some owners went through I am not suggesting them other than using be quiet! Silent Loop because I know be quiet! has good customer support.Oops, edited it out.
Ok cool. I'll have a shop around and see what i fancy. If they are coming out with the X3 might just wait for that and see what the reviews are.
