We discussed quite a bit here if this helps...
https://www.overclockers.co.uk/forums/threads/which-4k-uhd-blu-ray-player.18907959/
I personally went Sony X800 for my cinema room which will be up and running this Sunday... I currently run a Panasonic DMP-UB700 which has been fantastic for the past few years as I do like Panasonic gear... doesn't help but yeah the Sony is good value and built SOOOO much better than the Panasonic, weighs a ton for what it is.
Lets be honest you shouldn't have to, it should just autodetect the signal and switch internally, it's a stupid thing to manually have to change something. This all comes down to budget and whether you require DV... for me, I got the 800 over the 700 simply because I want to start a high defo music collection and I didn't need the DV of the X700... as my PJ isn't DV enabled and the cost 3 years ago I won't be changing so DV isn't a requirement for me especially as its not a default format on ALL 4k's...Thanks, I'm clearly blind, I missed that thread!
How much of a faff is it to switch between DV and standard HDR10? If it's quick to do, then i'm sure I could get on with it.
I'd deffo go with that... under £300 rips, you'd be foolish if you want ALL the standards this does it all apart from hi def audio which 99.9% of people are not interested in... so, yeah deffo good call. Itll be my upgrade if my current Panny goes **** upI just ordered a UB820 from Curry's. If you can use blue light discount you'll get it for £280.
Probably the best player at this mid range level.
Yeah that's my one problem I don't think Panny looks too hot, BUT it's dfunctionally the best for me deffo...Wish it looked nicer and wasn't 43cm wide as it won't fit in my rack. Not without it looking asymmetrical. We can't be having that![]()
This. The ub450 ain't bad either. I bought it for my dad last Christmas and it's great.I just ordered a UB820 from Curry's. If you can use blue light discount you'll get it for £280.
Personally I would have got a next gen console.
They will receive firmware updates for years to come whereas I doubt any blu ray player will be supported in 3 years never mind 7 years time like a console.
Also a lot more resources will be out into the consoles to improve then with time.
Expensive I know but then you also get a media player and a console to boot.
100%, my 4k player blows my 4k console for PQ, however, if getting a console then yeah makes sense but like you say I'd never ever buya console for 4k veiwing only, as the quality isn't there. However, yes, arguably more supported, but I've been running 4k since day one and perfect in living roomDedicated player is arguably better than a 4k console.
I'm not sure why it would, Id have thought the processing power of a console to be in another league compared to a blu ray player (I know a console is a bit of a jack of all trades).100%, my 4k player blows my 4k console for PQ, however, if getting a console then yeah makes sense but like you say I'd never ever buya console for 4k veiwing only, as the quality isn't there. However, yes, arguably more supported, but I've been running 4k since day one and perfect in living room
Because it's not dedicated, there is a notiable difference but tha's always been the case with DVD/Bluray and 4k... it's like looking at Netflix 4k and comparing to a top end disc.. it's good, but not as good lol. It's like playing a CD on an Xbox, yes it'll play, but compared to a nice Marantz Cd Player it'll be blown into the weeds.I'm not sure why it would, Id have thought the processing power of a console to be in another league compared to a blu ray player (I know a console is a bit of a jack of all trades).
If you already have a good console it just makes sense to use it rather than buying a low end 4k player.
