best card for £200
hrm...lack of warranty on that would really concern me.
To be honest the 5800 series are great, but at higher resolutions having had a 5850 clocked to 875/1250 and a 6950 at stock, the 6950 is much much better- they are not quite as good a deal as they were though and will be noisier.
which will be noisier ?
Hmm.... Lack of warranty. Did you read my post at all. BRAND NEW, FULL 2YR WARRANTY. It shouldn't be this difficult !!:)
Why is it that ati don't seem to have any decent warranties? I really like to see 4year + as thats generaly how long I keep my card. Typicaly I have a BFG card which used to have the best warranty money could buy and now they went bust and I have no warranty :(
It is only 6 months if you read the small print.
This is a far better deal IMO if you want an Nvidia solution
http://www.overclockers.co.uk/showproduct.php?prodid=BG-183-MS&groupid=595&catid=683&subcat=
2 years and a better cooler but you are getting too close to 6950 prices.
For about £200 the best is this
http://www.overclockers.co.uk/showproduct.php?prodid=GX-021-HS&groupid=701&catid=56&subcat=1866
ty for replys, what does B grade mean? was it rma?
oh my current system is i5 760@4ghz, 4gb ddr3 n Asus P7P55D-E, if that changes anything
id avoid the b grade personally.
if you upgrade often (<2yrs) id get the 5850 and put the £60 to one side for your next upgrade.
if you want a card that will last as long as possible for your £200 get the 5870 for £190.
'It is only 6 months if you read the small print'
WTF!! That warranty said two years in the description and has been changed to six months. Been posting all over what a great buy this card was and then Ocuk change the details. Pretty shady Ocuk and do you mind explaining why the warranty is reduced from 2yrs to 6 months on a new card.:mad:
