--|Best case awards|--
I would build it in MDF with a removable motherboard tray from another machine to see if it works.
If you were friendly with a metal working shop this would be easy to knock up as a prototype.
I'm thinking about building my own case now, or at least HEAVILY modifying my Antec 300....
Why would you build it out of MDF anyway? I've always found metal far easier to work. You could build a full aluminium case! :P
Ahh, aye I see your point. I'd probably use stainless sheet though, which I can get for next to nothing. :D
I think it's between
Akasa Eclipse (ahead of it's time and cant really appreciate how great it is until you own one, still fitting any card or hardware you throw at it all these years later speaks volumes)
Lian li pc7 ( simple good design and good looking similar design to the eclipse only smaller and better looking)
Antec p180/182/183
My vote goes to the antec never owned one but can appreciate the revolutionary chamber layout design, maybe I am wrong but the 180 was the first case to split up in to chambers like that ? and other manufacturers have followed ? even the lian li v series & tj07 corsair 800d amongst many are ripping it off ?
all these votes for the ATCS CM 201 make me think i should hang onto mine, I've been using it for about 8 years and still going well, although right now it needs a Dremel or something taken to it so i can actually get my OCZ power supply in instead of it being propped on top.
This if someone actually builds it...
The guy has real talent, check out his extremely detailed design 1 & 2.
looks stupid the fans at the top and bottom wont do anything but add noise :S
Let the SFF people join.
Hoojum Cubit 3 for its simple design and beauty! (Admittedly costs too much, hard to get hold of and limited to what you can put inside, but thats not the point)
Else PC7+ for its all round layout, cost and looks
or
Chieftec Dragon for being so great to mod back when.
Mines for CUBIT3 :D
Off Topic.
I've never moderated a forum that allowed a poll with as many choices as there are on the front page.
Think you'll need to short list it to 10 or something.
