Permabanned
- 10 Jun 2005
ok what are the best case fans around, as in most powerful yet very quiet as i will probably put 5 of these in and i need them as quiet as possible
bbreezeuk said:akasa ambers= fair compromise between silence and airflow
ASUS COOL UK said:The best fans I've found are the Thermaltake 'Thunderblade' 78cfm @ 21dB (£5.82), or the 'Silent cat' @ 63cfm @ 16dB!! (£5.82)
Unfortunately they dont sell them at Overclockers but you can find them at A PLACE SOMEWHERE ! (IT DID SAY A COMPETITOR)
I've got 2 YsTech 120mm from overclockers on a fan controller they push about 70-80cfm at 21dB(measured with dB meter) but when gaming I can turn them up max and they push 125cfm @ 35dB.
TaKeN said:EDIT The competitor site adress quickly otherwise you will be spending a long holiday from the forums lol...
nick_lerwill said:what is the best 80mm fan though? whats the 'Vantec TD8038H Tornado 80mm fan' like is it very loud?
hence the name tornadonick_lerwill said:what is the best 80mm fan though? whats the 'Vantec TD8038H Tornado 80mm fan' like is it very loud?
