- 21 Oct 2011
- ST4
Wired XBox 360 pad for me.
I was looking for a confrable option for kids, the xbox can be a little big in some hands.
Thanks for the replies, one of the main reasons I thought about upgrading is the wireless feature because I have on board Bluetooth but ive been told I still need to have a cable connected to use the controller.
Is this correct ?
So i assume you need to buy a separate dongleBoth my kids have Xbox One Controllers, age 6 and 9 they use them fine. They hardly use them anyway except for FIFA as they are true PC Gamers ie mouse/keyboard
Xbox One Wireless controller uses plug in USB dongle, no wire, hence why its "wireless"![]()
its just bluetooth isn't it?So i assume you need to buy a separate dongle
Thanks, how long do batterys last in the xbox one controller and how long does the pack last ?
. It's apparently a common issue and something I could see being an issue as soon as I used the pad for the first time as the tumb sticks just feel so weak and creaky from new.
.Wired XBox 360 pad for me.
I changed from a 360 pad which was getting tired to a XB1 pad. I'd say it's an upgrade, but there are two downsides I found worth considering:
1) The XB1 pad gives NO warning at all that batteries are running low. So the first you will know is when it suddenly stops working. Which is usually right in the middle of a Rocket League game. I've actually had it happen just as I was about to tap jump to score.
2) I used it with a bluetooth dongle for a long time. It was usually OK, but occasionally a bit dodgy. And when I got a VR headset it went very flaky for some reason. Switched to the official wireless connection instead and it's been 100% reliable since.
I hope MS don't change the Xbone controller too much for their next gen console as it really fits in to my hands just perfectly.
